New engine
Diseazd
Both cams idle pretty much as stock. The Stage III has a little tiny bit of lope. The Stage III just feels stronger through all RPM bands. Jon Mortenson is right.......there is no reason not to go Stage III. The only mod you need is the shorter valve seals when you exceed .460 inch lift......plus the performance valve springs and retainers of course.
Would you mind sharing your coating method for the following....
Exhaust manifold
timing cover
valve cover
If you are painting yourself, could you share the name of the products?
Also, did you paint the original crank pulley or is it rebuilt / new?
Looks fantastic. Can't wait to hear how you like this sort of unique combination of engine parts.
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
