New engine
Diseazd
I've been busy building my engine. The race is in a little over a week. Here are a few pics of the timing with the decked head and no tower shims. It's a little too pretty for a ChumpCar engine, but it should run pretty well. :cool:
I used a degree wheel and the cam card. It's a fairly slow process, but it gets it exactly right.
  • Find #1 TDC and set degree wheel to TDC using a piston stop.
  • Measure 0.050" #1 exhaust valve open and compare to cam card
  • Measure 0.050" #1 exhaust valve close and compare to cam card
  • Install offset bushing that moves cam the right direction to match cam card
  • Repeat until valve timing matches cam card
I really like my Mitutoyo digital dial indicator, but it wasn't cheap. Spend the money to get a good magnetic holder as well. My Craftsman one is serviceable, but I wish I would have bought a better one. You will also need to make a piston stop. The easiest way is to break the ceramic out of a spark plug and insert a long bolt with the end rounded. Mine was made about 20 years ago in 15 minutes, so it's really crappy, but it does work fine. Someday, I will redo it by welding the bolt to the spark plug rather than rely on all of the washers and the nut. The degree wheel is actually made of wood by downloading a jpg of a degree wheel and cutting/etching it on a CNC laser. My racing teammate made it at the Tech Shop which is a local shop that is run like a health club with monthly membership dues.
Do an internet search on how to use a degree wheel to get the full instructions.
I will give a complete review after my race on the 13th.
I am also adding a flex pipe to the exhaust right behind the header collector to take the strain off the manifold studs. Once the engine and exhaust are installed, I'll take more pics. I'm using the slip together MSA 2-1/2" exhaust system.
  • Who's Online   1 Member, 1 Anonymous, 843 Guests (See full list)
