Is that measured flush? What HG are going to run?
[ATTACH=CONFIG]64440[/ATTACH][ATTACH=CONFIG]64439[/ATTACH][ATTACH=CONFIG]64441[/ATTACH]
Installed the .040 over ITM pistons. Torqued the main and connecting rod caps. Looking good. BTW Madkaw...the pistons are flush with deck.
It's not about keeping the pistons flush- it's about setting up proper head to piston clearance based on the head gasket used. Thru research I have read that the best set up is .022-.027 clearance , but that might be too tight for some comfort levels. It's all about ideal parameters to fight detonation.
I'm running about .027
Most stock Nissan L motors have a pistons above the block from .014- .019
  • 2 months later...
Went to work on the Z Doctor P79 head today. I geometried all the wipe patterns for the Isky Stage III cam and valve springs. All rockers centered out with .160 lash pads except 2 which were .150's. I use an old egg carton to keep everything in order. Hope to start reassembly soon.
  • 3 weeks later...
