Posted June 6, 201113 yr comment_357903 The plastic block that holds the horn contact on the steering column has broken. Can someone help me find a replacement part? I have a late 1973 240Z. Link to comment https://www.classiczcars.com/forums/topic/39804-steering-column-horn-contact-mount/ Share on other sites More sharing options...
June 6, 201113 yr comment_357930 Is it the original horn? Autozone sells a horn button that you might be able to put on. Link to comment https://www.classiczcars.com/forums/topic/39804-steering-column-horn-contact-mount/#findComment-357930 Share on other sites More sharing options...
June 6, 201113 yr comment_357931 Mine was broken also, a dob of super glue & the holding screw put it back together again.Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/39804-steering-column-horn-contact-mount/#findComment-357931 Share on other sites More sharing options...
June 6, 201113 yr Author comment_357963 Thanks guys, a little bit of epoxy and it's all better. Link to comment https://www.classiczcars.com/forums/topic/39804-steering-column-horn-contact-mount/#findComment-357963 Share on other sites More sharing options...
