Posted June 12, 201113 yr comment_358425 I can't seem to find much info. Would it be better to have another oil pump on my 71 Z ( from a 280, etc. ) or is stock OK. thank you, timsz Link to comment https://www.classiczcars.com/forums/topic/39864-71-oil-pump-upgrade/ Share on other sites More sharing options...
June 12, 201113 yr comment_358426 The stock pump is sufficient for a stock lubrication system. If you modify the lube system (for example - change to internally oiled cam, or run both oiled cam AND spray bar), you may wish to you a pump from a 280ZX Turbo. Link to comment https://www.classiczcars.com/forums/topic/39864-71-oil-pump-upgrade/#findComment-358426 Share on other sites More sharing options...
