Posted June 12, 201113 yr comment_358452 Can anyone help?Recently purchased a 74 260Z , first Zcar, and all other lights ect. work just don't have headlights or dash lights?? have checked fuse in lower right hand box , they look ok, any other suggestions what could be the problem?Thanks for any helpMick Link to comment https://www.classiczcars.com/forums/topic/39869-need-help-no-headlights-or-dashlights/ Share on other sites More sharing options...
June 12, 201113 yr comment_358487 While those two circuits are controlled by the same switch, they are almost completely electrically isolated from each other. Did you look through other posts here and try those suggestions?Have you looked at the factory service manual? The circuits are drawn well in the Body Electrical section. Find a link to it below. Link to comment https://www.classiczcars.com/forums/topic/39869-need-help-no-headlights-or-dashlights/#findComment-358487 Share on other sites More sharing options...
