Posted June 15, 201113 yr comment_358839 Hello again, I keep asking questions, so here's a new on. After finally fixing my electrical problem yesterday, I got the car running. It started on the first try. I took it for a test ride to a friends place, driving 20 miles in total. I hit 6000rpm a couple of times on the way. On my way home I noticed a new sound, which I didn't like. It's a squeaking or grinding kind of sound. It's hard to locate, but to me it sounds like it coming from somewhere around the front part of the engine, or front part ( a bit to the right) of the engine bay. I added two videos for your reference. I appreciate all your help. Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/ Share on other sites More sharing options...
June 15, 201113 yr comment_358843 Sounds like the cam is running dry, better pop the valve cover and check out the oiler. Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/#findComment-358843 Share on other sites More sharing options...
June 15, 201113 yr comment_358856 Sounds like the cam is running dry, better pop the valve cover and check out the oiler.Yep, good chance it's that. Early 240Z oil bars are notorious for falling apart. Mine did, and ended up in the oil pan. Luckily I didn't run it long before I noticed. After you check the oiler, do a visual check of the cam and run a finger across the cam lobes to feel for any wear. Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/#findComment-358856 Share on other sites More sharing options...
June 15, 201113 yr comment_358860 Just a thought, but it appears that you probably have at least one idler pulley under the hood for the A/C compressor. I would do a little oil on the idler pulley bearings to see if you can make that noise go away. Idler pulley bearings are quite often a culprit and make that kind of sound. Hope this helps.Dan Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/#findComment-358860 Share on other sites More sharing options...
June 17, 201113 yr Author comment_359051 I removed the valve cover today, did not see any noticeable wear on cam. Looks like it is getting the oil it needs.I'll look in to the pulley idler this weekend. Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/#findComment-359051 Share on other sites More sharing options...
June 18, 201113 yr comment_359055 Grab a hold of water pump pulley see if it wiggles. Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/#findComment-359055 Share on other sites More sharing options...
June 18, 201113 yr Author comment_359090 Will do BGM. Seems I forgot to mention the noise only appears above 3000 rpm. Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/#findComment-359090 Share on other sites More sharing options...
June 18, 201113 yr comment_359093 You can use a mechanics stethoscope and find it quickly. It may be one of your accessories or even a fan clutch that is seized and the fan is hitting something. Beware of mechanics who try to look like Freddy Mercury. Edited June 18, 201113 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/#findComment-359093 Share on other sites More sharing options...
June 18, 201113 yr comment_359097 Front right could be an alternator bearing. It does sound like a bearing that's gone south. Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/#findComment-359097 Share on other sites More sharing options...
June 18, 201113 yr Author comment_359129 So today I finally had time to take a look at the problem. I found out the fan belt had a lot of slack. Almost embarrassed I didn't see it first. After adjusting the alternator, tightening up the belt. I fired her up and went for a test ride. The grinding noise was gone. Considering how nasty the sound was, I was happy the fan belt was the only problem.Now I'll just need to get to the next point on my check list. Finding out why the car has a higher idle when warm, why it sometimes loses power, and dies. Getting the doors to close and so forth. So bear with me and my questions, as I don't have to much mechanical experience, yet. Thank you for your answers. Edited June 18, 201113 yr by Koss Link to comment https://www.classiczcars.com/forums/topic/39904-squeaking-grinding-sound/#findComment-359129 Share on other sites More sharing options...
