Quick Checklist
0. Visual Inspection: belts, hoses, wiring, rodent damage/nesting
1. drain gas and flush tank with acetone.
2. drain oil
3. drain coolant and replace thermostat, flush out system with a garden hose (there is a drain on the block near cylinder 5 on drivers side).
4. pull plugs pour ATF or spray anti-seize (pb blaster/liquid wrench) into plug holes
5. turn motor at crank nose to ensure rings are not seized
6. remove valve cover, oil cam, remove oil bar, use canned carb cleaner and straw to spray all holes in oil bar to back flush
7. re-install oil bar, replenish oil, and crank engine with plugs out and watch for oil bar to start squirting. Make sure all holes are oiling the 12 cam lobes.
8. blow gas lines back into tank
9. replenish coolant and gas
10. crank and check for spark
11. Check electrical system. Voltage at battery should be 12.6 to 12.8 with car off and ~13-14.5V with car on . Also check for corrosion in wires and at fuse block.
12. Verify injector operation
13. Check fuel and brake system
14. Check suspension and wheels/tires
15. Start car and check gauges/engine function/exhaust/ cooling system/ charging (watch for burning wires in cabin, coolant leaks in system and in cabin)
16. Take on a few drives within pushing distance to your home and resolve any issues. (gunk in fuel tank may take a mile or two to clog the filters or fuel pickup!)
Stuff you may need to replace:
fluids
plugs
plug-wires
coil
distributor cap & rotor
tires
battery
water pump
air filter
clutch slave (seals)
rear wheel cylinders (seals)
fuses
Thermostat
fuel filter
Mostly you need a lot of time and money.
But seriously (the above was serious, but rude...) First you need to consider the amount of rust, or more accurately the degree to which structurally significant portions of the car are missing. Make sure that the unit body is repairable before you start throwing money at the restoration.
How bad is "pretty bad?" Does it just have a small hole or two around the rear fenders, or is it a complete basket case, with holes in the floorboards, rocker panels, doors, frame rails, etc. Almost all of these cars have a bit of rust somewhere. The question is, "How much?"
Well basically where the taillights are all rusted out near the license plate, the area right under the hood is falling apart and the roof is rusted but isnt to bad. the interior seems fine but its mostly the body in the under areas
Ill post pics ASAP
