Some jagoff used a 1600 ft lbs. torque wrench apparently to put this POS gland nut on this crappy Datsun designed strut tube (heaven forbid you actually you use a real strut instead of this cartridge) assembly. I have big arse set of channel locks and the strut clamped in my vise below the spring perch and this sonofabitch is not turning. Do they make a socket for an air impact to get this nut off? How do you get these off without destroying your tube and spindle? How deep does this thing go in to the tube? My struts I can put by hand in to the tube and they don't pop back out, would it be safe to apply heat? Whoever thought of this at Datsun is a retard.
https://www.classiczcars.com/forums/topic/39987-m-fer-gland-nut-need-help/
FWIW, the strut tube design on our S30s is totally standard practice for the '70s. I can't recall any car maker using a complete (i.e. sealed) strut assembly until the early '80s. The tube/insert design was used by Datsun, Toyota, Mazda, VW, Audi, Fiat, Ford-Europe, etc. Nothing unusual for a car of this age.
Arne I was born in '81 this is all I know. This car is older than me!
Tried MAPP gas and a hammer with large screw driver, not even close to budging. These things don't look like they rust, why are they so tough? This made my spindle pins seem like a brake pad change. Hopefully when I borrow a pipe wrench that will do it.
This is a pain in the you know what on some struts. I've had to weld a fat 1x1 steel rectangular bar to gland nut and use 36 inches + of cheater bar to get one set to break free. This even after several days of penetrant soaking and heat treatment. I just hate heating shocks though, definite explosion risk there....
Sounds like you're having fun! I'm waiting for the post about your spindle pin removal!
Spindle pins are out, took me about 90 minutes a side.
