Posted June 28, 201113 yr comment_360050 I am restoring a 71 240z with fibreglass rear quarter panels.The installer of the panels did not remove the fuel filler line (~ 2.25" pipe) directly below the gas cap because of either laziness or because of hole size.I now wish to remove it and install it properly but I will have to cut it out as it is sandwiched at the top between the quarter panel and some inner metal . It is not pliable so I can not pull from the top or bottom (the 3 big philips screws on the back are off)Since the existing line is very hard and it seems harder than I recall on my 280z; I am hoping that a replacement part will be pliable so that I can fit properly.Does anyone know if these lines harden over time? Are new ones softer? Link to comment https://www.classiczcars.com/forums/topic/40049-hardness-of-large-fuel-fillerline-to-tank/ Share on other sites More sharing options...
June 28, 201113 yr comment_360051 Mine (73) is not new but it feels soft, like a radiator hose, hope it helps. Link to comment https://www.classiczcars.com/forums/topic/40049-hardness-of-large-fuel-fillerline-to-tank/#findComment-360051 Share on other sites More sharing options...
June 28, 201113 yr comment_360053 I did replace mine. The original was very stiff, the replacement was quite flexible. Link to comment https://www.classiczcars.com/forums/topic/40049-hardness-of-large-fuel-fillerline-to-tank/#findComment-360053 Share on other sites More sharing options...
June 28, 201113 yr comment_360057 I had to heat mine up with a blow dryer to soften it. My gas tank wasn't anywhere near the car so I had no worries of ignition. Link to comment https://www.classiczcars.com/forums/topic/40049-hardness-of-large-fuel-fillerline-to-tank/#findComment-360057 Share on other sites More sharing options...
June 28, 201113 yr comment_360058 With SOME of these old rubber parts, I found they respond to laquer thinner and/or acetone or MEK. Soak a rag with the stuff and wrap it around the hose for a few minuts and it will get soft and expand. It will also destroy the part, so not good if you need to reuse it. But this is a good trick for removing hoses from thin or delicate brass and aluminum nipples before going after them with blades and pry bars. Link to comment https://www.classiczcars.com/forums/topic/40049-hardness-of-large-fuel-fillerline-to-tank/#findComment-360058 Share on other sites More sharing options...
June 28, 201113 yr comment_360062 I just happen to have a new, still in factory wrapper, one here in my office awaiting installation on my '71. As others have said, soft and flexible like a radiator hose.Dennis Link to comment https://www.classiczcars.com/forums/topic/40049-hardness-of-large-fuel-fillerline-to-tank/#findComment-360062 Share on other sites More sharing options...
June 28, 201113 yr Author comment_360063 Excellent and quick feedback gang! I'll try the heat first.THANKS! Link to comment https://www.classiczcars.com/forums/topic/40049-hardness-of-large-fuel-fillerline-to-tank/#findComment-360063 Share on other sites More sharing options...
June 28, 201113 yr comment_360074 The trick is getting enough heat, but not too much.... Hair dryers are just barely enough, propane torch is too much (and there's that open flame thing...) , but I find paint stripper heat guns (hair dryers for bald men!) to be the best. Hot enough to burn me, but not hot enough to melt the hose unless you leave it on one spot for a LONG time... Link to comment https://www.classiczcars.com/forums/topic/40049-hardness-of-large-fuel-fillerline-to-tank/#findComment-360074 Share on other sites More sharing options...
July 1, 201113 yr comment_360296 I just bought myself a replacement filler tube from the junkyard the other day. It was somewhat pliable and I was able to squeeze it through the top opening and the metal ring inside the quarter panel. The same car also gave up its brand new rear diff mount....a productive junkyard recce I must say. Link to comment https://www.classiczcars.com/forums/topic/40049-hardness-of-large-fuel-fillerline-to-tank/#findComment-360296 Share on other sites More sharing options...
