Posted July 7, 201113 yr comment_360861 My passenger side half shaft is very stiff. I pulled it apart cleaned it thoroughly and reassembled. It is still a little stiff but I do not get the travel I do with the drive side unit.I may have put too much grease into it. Are the half shafts usually stiff to slide or do they usually slide easily. Going to take it apart again now. Link to comment https://www.classiczcars.com/forums/topic/40127-half-shaft-maintenance-problem/ Share on other sites More sharing options...
