the only thing found was a sticky door not sure if one of the dash pots go to it and if its bad im 2000 miles away from the car and fsm so i need some hepl from the smart people here i know someone has had to of had this problem
Vacuum leak - very likely in the small tubing on or near the mag valves, vacuum canister (aka 'football'). Cuts in the tubing between canister and the mag valves and, and ultimately, to the selector switch/valve (behind center dash) would mean no control of doors (floor/defrost/dash) or mode (heat/ac/vent). And easier to find, being under the hood, rather than inside the dash . Default is air flow from center vents. Unless there was a mechanical failure (diaphragm valve/return spring, etc.), my bet is a cut or split in the tubing. Every one that I have found is near the end of a tube where it slips over a pipette or a 'T'.
