Recommended for Cleaning Clear Coated Rims
240260280z
I cleaned clear coated aluminum rims today. At first I just used soap, 3 different scrub brushes and a scotchbrite pad.
There were dark spots in the "corners" and deep in the wheel where the brake dust would not come off even with the scotchbrite pad (rougher sand cast areas). I had a wheel solution that I forgot about and gave it a try. Wow, it cleaned everything with just a gentle srubbing action after a 30 second soak. I strongly recommended it: Meguiar's Hot Rims All Wheel Cleaner. It works.
Edited by Blue
