Recently Browsing 0
Who's Online (See full list)
My rear end is 3.545
Current transmission is
1 - 3.321
2 - 2.077
3 - 1.308
4 - 1.000
5 - 0.864
The trans im looking at is this
1 - 3.062
2 - 1.858
3 - 1.308
4 - 1.000
5 - 0.745
I feel when im going through gears the powerband drops off when going to 3rd, i want to remove this.
I also drop a lot of RPM while shifting. with this new transmission my 1st-2nd gear should have slightly slower acceleration but a higher speed in each gear with the benefit of being closer to each other it should be slightly "faster" correct?
Will swapping to the new transmission alleviate this problem?
https://www.classiczcars.com/forums/topic/40182-transmission-ratios-acceleration/Share on other sites
