Question about KA24 pistons in L28
EricB
Hi all
Based on this chart:
http://www.zhome.com/ZCMnL/tech/128combo.html
I've decided on going the 2949cc route by way of L28 block + L24 rods + KA24 pistons in STD 89mm width
That chart lists part number 12010-40f10 for the std diameter 89mm unit and lists a zero cc dish volume. I assume that means these are flat top pistons.
However when I look up this p/n I invariably find images of the dished Ka24de turbo piston
And then when doing a similar p/n search on nismoparts.com I came across an advertised Ka24 flat top piston but with a slightly different part number: 12010-40f72
Can someone confirm which is the right p/n before I place a non-returnable special parts order at the dealership please?
Thx
-e
  • 1 month later...
BTW all I just heard back from Nissan
Both pistons 12010-40F72 and 12010-40F10 are now NLA from Nissan/Nismo...
F72 is the high perf flat top piston listed in the S13 section of the Nismo catalog
F10 is the piston listed for use in the 2949cc L24rod/L28crank combination here http://www.zhome.com/ZCMnL/tech/128combo.html
So aftermarket as listed above is the only way to go... bummer...
  • Who's Online   1 Member, 0 Anonymous, 950 Guests (See full list)
