Posted July 18, 201113 yr comment_361845 Hi allBased on this chart:http://www.zhome.com/ZCMnL/tech/128combo.htmlI've decided on going the 2949cc route by way of L28 block + L24 rods + KA24 pistons in STD 89mm widthThat chart lists part number 12010-40f10 for the std diameter 89mm unit and lists a zero cc dish volume. I assume that means these are flat top pistons.However when I look up this p/n I invariably find images of the dished Ka24de turbo pistonAnd then when doing a similar p/n search on nismoparts.com I came across an advertised Ka24 flat top piston but with a slightly different part number: 12010-40f72Can someone confirm which is the right p/n before I place a non-returnable special parts order at the dealership please?Thx-e Link to comment https://www.classiczcars.com/forums/topic/40236-question-about-ka24-pistons-in-l28/ Share on other sites More sharing options...
July 18, 201113 yr comment_361847 zero cc dish volume should be flat tops, can you do a cross reference part search and check the nissan truck that came with the ka24 flattops stock? Link to comment https://www.classiczcars.com/forums/topic/40236-question-about-ka24-pistons-in-l28/#findComment-361847 Share on other sites More sharing options...
July 18, 201113 yr Author comment_361861 D21 Trucks and S13 240SX with Ka24 engines use the flat top piston with p/n 12010-40f72Does that settle it then? Link to comment https://www.classiczcars.com/forums/topic/40236-question-about-ka24-pistons-in-l28/#findComment-361861 Share on other sites More sharing options...
July 19, 201113 yr comment_361876 I dug this up from rockauto, these are the pistons you need. BECK/ARNLEY Part # 0125195 SEALED POWER Part # H832CP DNJ ENGINE COMPONENTS Part # P616 30$ each, beck arnley comes with rings. Link to comment https://www.classiczcars.com/forums/topic/40236-question-about-ka24-pistons-in-l28/#findComment-361876 Share on other sites More sharing options...
August 26, 201113 yr Author comment_364847 BTW all I just heard back from NissanBoth pistons 12010-40F72 and 12010-40F10 are now NLA from Nissan/Nismo...F72 is the high perf flat top piston listed in the S13 section of the Nismo catalogF10 is the piston listed for use in the 2949cc L24rod/L28crank combination here http://www.zhome.com/ZCMnL/tech/128combo.htmlSo aftermarket as listed above is the only way to go... bummer... Link to comment https://www.classiczcars.com/forums/topic/40236-question-about-ka24-pistons-in-l28/#findComment-364847 Share on other sites More sharing options...
August 26, 201113 yr comment_364857 Does this help? http://www.geocities.com/inlinestroker/index.htm Link to comment https://www.classiczcars.com/forums/topic/40236-question-about-ka24-pistons-in-l28/#findComment-364857 Share on other sites More sharing options...
