Posted July 20, 201113 yr comment_361972 I see weld-in camber plates for my 71. I also see where welding in strut towers where plates go is not a good ( strong ) place to weld because of layers of metal. should I weld camber plates in or not? any opinions. thank you, timsz. Link to comment https://www.classiczcars.com/forums/topic/40251-weld-in-camber-plates/ Share on other sites More sharing options...
July 20, 201113 yr comment_361978 There are two layers of metal: a thin sheet metal on top and a thicker (guess about .120) reinforcing plate underneath. If you weld plates in I would suggest doing whatever you have to in order to ensure you hit the bottom plate with your weld. It's really not hard to do, just turn the welder up to get proper penetration on the plate underneath and you'll burn right through the sheet metal. The other option is Ground Control's bolt in plates. I think they're the best out there for Z's at this point, because they don't have the weight of the car sitting on the 5/8" monoball, and the newer ones allow the spring to stay straight underneath the plate, so the spring doesn't get bent sideways and rub the threads on your coilovers as much. Link to comment https://www.classiczcars.com/forums/topic/40251-weld-in-camber-plates/#findComment-361978 Share on other sites More sharing options...
July 20, 201113 yr comment_361993 http://www.ground-control-store.com/products/description.php/II=151/CA=191 Link to comment https://www.classiczcars.com/forums/topic/40251-weld-in-camber-plates/#findComment-361993 Share on other sites More sharing options...
