Posted July 31, 201113 yr comment_362849 Will an L28 engine bolt directly to a original 240Z Automatic Transmission? I am looking to use the Z for Bracket Racing and the automatic trans will provide the greatest continuity between runs. What modification, if any need to be made? I have not seen this subject covered anywhere in this forum. Thank you for your time. Link to comment https://www.classiczcars.com/forums/topic/40354-280zx-auto-trans-swap/ Share on other sites More sharing options...
July 31, 201113 yr comment_362870 Yes, a 240Z auto (3n71b) will bolt to the back of an L28.For serious dragging with consistancy, why would you run anything else?Good idea and good luck. Link to comment https://www.classiczcars.com/forums/topic/40354-280zx-auto-trans-swap/#findComment-362870 Share on other sites More sharing options...
