Posted August 1, 201113 yr comment_362994 When i put the car in the reverse it doenst shift smoothly,the gear make a crackeling sound i am able to shift all other gear with no problem.Do i need to adjust the clutch??any one who as had the same problem please let me know ,it will be great.Thank you sergio Link to comment https://www.classiczcars.com/forums/topic/40370-reverse-noisy/ Share on other sites More sharing options...
August 2, 201113 yr comment_363016 It's not a problem, there is no syncro on reverse and it's a straight cut gear,try putting it in second before reverse. Link to comment https://www.classiczcars.com/forums/topic/40370-reverse-noisy/#findComment-363016 Share on other sites More sharing options...
August 2, 201113 yr comment_363031 You can try redline mtl transmission fluid. That can help some problems however something could be worn or loose in the transmission. Link to comment https://www.classiczcars.com/forums/topic/40370-reverse-noisy/#findComment-363031 Share on other sites More sharing options...
August 3, 201113 yr Author comment_363117 Thank you both for your reply I will try this weekend and let you know,it was fine until i had my oil pan and the clutch cylinder got changed, also to do the job the gears box was removed, but not opened, could that be a factor also???regardsserge Link to comment https://www.classiczcars.com/forums/topic/40370-reverse-noisy/#findComment-363117 Share on other sites More sharing options...
August 3, 201113 yr comment_363118 Just pulling the transmission for the other services would have no affect unless the persons doing so did one of the following mentioned below (that assumes there was no problem before that service). As noted, there is no syncro on reverse. These gears usually get chewed up by impatient drivers that force the transmission into reverse while the vehicle is rolling forward or somehow miss a downshift from fifth to fourth and find reverse by mistake. I've had to replace these gears in every gearbox rebuild except for one unit. It won't affect operation unless a bit of gear tooth manages to get into any of the other gears causing crashing of metal. Edited August 3, 201113 yr by ezzzzzzz Link to comment https://www.classiczcars.com/forums/topic/40370-reverse-noisy/#findComment-363118 Share on other sites More sharing options...
August 3, 201113 yr comment_363125 sdelage said: it was fine until ..........the clutch cylinder got changed, You might need to bleed the system a little better or adjust the pedal linkage to get more travel in the master cylinder. Were both cylinders changed or just the slave cylinder? Link to comment https://www.classiczcars.com/forums/topic/40370-reverse-noisy/#findComment-363125 Share on other sites More sharing options...
August 4, 201113 yr Author comment_363192 Thank you both,for your quick responses only the Slave cylinder was changed by a Nissan mecanic,and on the bill it say that brake oil was used...Dont know what oil it should have used if it make a difference.Let me know????RegardsSerge Link to comment https://www.classiczcars.com/forums/topic/40370-reverse-noisy/#findComment-363192 Share on other sites More sharing options...
August 4, 201113 yr comment_363198 yes the clutch and brake systems use same fluid (dot3 brake fluid) Link to comment https://www.classiczcars.com/forums/topic/40370-reverse-noisy/#findComment-363198 Share on other sites More sharing options...
August 5, 201113 yr comment_363367 You could try taking it back to the Nissan dealer that worked on it. Possibly get a free fix if they messed up something.Bryce Link to comment https://www.classiczcars.com/forums/topic/40370-reverse-noisy/#findComment-363367 Share on other sites More sharing options...
