Email logins are now active ×
Tranny Oil
lenponz
I have a 5-Speed close ratio (i beleive) in my 240z.
Q: what is the correct oil to use for it?
the new stuff sold by Nissan is for the more modern trannys (very lite) but can i use it for this older trans?
Any suggestions
My 4 speed has 235,000 miles on it, There is no record of a rebuild and I have every receipt that went into the car from new. I just refilled with 75-90 Purple and the damm thing shifts great and runs quite. Me likeeee this stuff.
I run Redline MT-90 in mine.
Same here. The Redline made the shifting dramatically smoother.
You need a GL-4 oil, not a GL-5 oil. If you don't want to go synthetic, Pennzoil makes a non-synthetic oil that is supposed to be usable with "yellow metals" which should work. The synchronizers in the transmission are brass, and the sulfur that is in a GL-5 oil will make them brittle.
Last time I was looking, it seemed like non-synthetic GL-4 was tough to find. Fewer and fewer new cars use it anymore. Synthetics were a lot easier, for some reason. Numerous places had that on the shelf.
  • Who's Online   2 Members, 0 Anonymous, 218 Guests (See full list)
