August 8, 201113 yr comment_363576 I didn't know synthetic oil was bad for my transmission. I just changed the oil to synthetic. Should i change it again?Synthetic is ok. Just make sure it is NOT GL-5 gear formula with sulfur. Link to comment https://www.classiczcars.com/forums/topic/40408-tranny-oil/?&page=2#findComment-363576 Share on other sites More sharing options...
August 8, 201113 yr comment_363579 Thanks Blue. Its not GL-5. Its castrol synthetic gear oil. Link to comment https://www.classiczcars.com/forums/topic/40408-tranny-oil/?&page=2#findComment-363579 Share on other sites More sharing options...
August 8, 201113 yr comment_363580 Thanks Blue. Its not GL-5. Its castrol synthetic gear oil.As long as it's not Castrol 'Syntec' gear oil. That is GL-5. I have part of a container that was left over from working on my daughter in law's Lincoln LS. On the label it says 'Fully synthetic, API GL-5 and MT-1, SAE 75W-90 formula'. Link to comment https://www.classiczcars.com/forums/topic/40408-tranny-oil/?&page=2#findComment-363580 Share on other sites More sharing options...
August 8, 201113 yr comment_363582 I will look for the bottle. If I cant find it I will change it again to make sure. I love my old Z. Thanks foir the input. It will say G-L5 on the bottle or should I look for something else on the lable? Link to comment https://www.classiczcars.com/forums/topic/40408-tranny-oil/?&page=2#findComment-363582 Share on other sites More sharing options...
August 8, 201113 yr comment_363583 It says it on the back. Link to comment https://www.classiczcars.com/forums/topic/40408-tranny-oil/?&page=2#findComment-363583 Share on other sites More sharing options...
August 8, 201113 yr comment_363589 Thank you very much. I don't have the bottle so looks like an oil change (again) Link to comment https://www.classiczcars.com/forums/topic/40408-tranny-oil/?&page=2#findComment-363589 Share on other sites More sharing options...
August 10, 201113 yr comment_363718 I also use Redline MT90 (75w90) which is of the GL4 specification.Synth fluid for the z tranny is good as it protects better. Not all trannys appreciate synth, however (ie: wrx) Link to comment https://www.classiczcars.com/forums/topic/40408-tranny-oil/?&page=2#findComment-363718 Share on other sites More sharing options...
