Posted August 10, 201113 yr comment_363713 I have my rear spindles over at Andrew Streckfuss "ZCurves" brother's AAMCO putting in the new wheel bearings and grease seals. What is this crap about peening the nut that goes on the stub axle? What is peening? Shot peening is what they do to connecting rods to increase strength. Andrew if you are reading this I had to rob one stub axle nut off the parts car. I need the other one but your brother air impact won't get it off. Sounds like it is one of those things that you don't really need to do to your car, something no shop would ever do on a customer's car. Link to comment https://www.classiczcars.com/forums/topic/40451-peening-stub-axle-nuts/ Share on other sites More sharing options...
August 10, 201113 yr comment_363714 I think what they mean is staking the nut so it does not come loose. Link to comment https://www.classiczcars.com/forums/topic/40451-peening-stub-axle-nuts/#findComment-363714 Share on other sites More sharing options...
August 10, 201113 yr comment_363716 The real thing to be concerned with is that they know to cut the peened area off before taking the nuts off. If they don't they'll wipe the threads off of the stub axle from the peened area to the end. Link to comment https://www.classiczcars.com/forums/topic/40451-peening-stub-axle-nuts/#findComment-363716 Share on other sites More sharing options...
August 10, 201113 yr comment_363717 Get these. No need to stake/peen. They are from a 280zx and fit fine. The last threads have a "ripple" that holds them in place. Link to comment https://www.classiczcars.com/forums/topic/40451-peening-stub-axle-nuts/#findComment-363717 Share on other sites More sharing options...
