A day of testing
ll77
No, it isn't oily. It's crusty, definitely splashed onto the backside of the cover a one point. Very strange. I'll clean it, probably spray it with some contact cleaner. Ehh, I'm hesitant on ordering the boot by itself. I'm a bit neurotic about saving money on shipping see, and I have a lot of things I want to order. I am neurotically frugal LOL, my parents taught me well. I'm running a bit low on funds right now, but I'm waiting on news from my local Goodyear tire shop, my neighbor is in with the manager there, and he's waiting on some official business to happen before he hires me, then I'm officially a tire man! :cool:
Oh yes, news worth mentioning: a HybridZ man told me my lack of a PCV valve could be causing my lean condition, as the intake would be constantly drawing in unmetered air from the crankcase via the vacuum it produces. Less fuel would be injected than required, leading in a lean condition. Makes sense to me. This could also be causing my low vacuum, yes? I'm off to Autozone to pick up a cheapy PCV soon then, hopefully that'll make a difference. Ok off to bed now, very tired. :sleepy: I wouldn't be getting anywhere without my forum peeps, thanks!:)
The intake system pulls a vacuum on the crankcase when the PCV system is connected properly. So any leaks in the PCV or through the valve cover gasket or the big hose from the valve cover (actually part of the PCV system) are leaks in to the intake manifold, bypassing the AFM vane, causing a lean condition. All air must pass through the AFM for the EFI system to work correctly, no exceptions.
Are you sure that your PCV is missing? There's not much to it and looking from outside (how did you get your eyeball under there?) it looks like a flat disc sitting in a metal fitting. They do get gummed up (maybe that's the carbon), but can be cleaned with some carb cleaner.
I had the contact switch in my newly rebuilt AFM stop working right after I got it. I think that a small piece of debris got on to the tiny contact switch and kept it open. I never found whatever was holding it open, but after I mucked around with it and put it back together it's worked fine ever since.
Well, my patented yogurt cup test will tell you if you have a leak in the PCV circuit. However, you're not going to get much meaningful info with a humungous leak in the boot. Maybe you can hold your hand firmly over the mouth of the throttle body to seal the air?
A missing PCV valve would certainly introduce a huge vacuum leak (and lean running), but a malfunctioning PCV (but not leaking) would just result in a dirty engine. All of the PCV air is metered and simply makes a circuit through the crank case and valve cover.
Zed Head: Well, I popped off the hose coming from the intake to the block, and I understand the PCV is supposed to be plugged in at the block. What I felt was a plastic-feeling pipe coming off the side of the block, I didn't feel anything like a PCV valve in it. Now, if I was supposed to remove the pipe-fitting from the block to find the PCV, I didn't do that, but it really felt pretty damn stuck. I checked the hose, I pressed around on it, nothing. So I presumed the PO took it off for some reason. :stupid:
FastWoman: They're not huge leaks, just one small rip that I found. I'll hope that the RTV sealed it, and I'll try the test again when I get new boots. And that cigarette smoke test, I'm hoping to try that soon. That should yield some good results, right? :paranoid:
Hey guys, just got a PCV valve from autozone today, but the fitment doesn't make sense. I initially thought I could just stick it in the hose and that would be it, but I see there are threads on the valve, so that can't be right. But there are no threads on the blue plastic fitting sticking out of the block. I really don't know what's going on. How can the valve possibly seal up if it can't thread to the block? If I just stick it in there, the vacuum is still going to leak past the hex pattern on the valve, the fitting is circular. I'm stumped.
And I hope it's ok that I just keep posting in this thread and not make new threads for every question I have. I think that's better, less clutter yeah?
Edited by ll77
The PCV valve screws into the underside of the intake manifold, about in the middle, and closest to you, as you view the engine from the driver's side. Obviously the hose then clamps to the barb on the PCV valve. The other end of the hose leads forward and downward, connecting to a pipe that comes out of the lower front driver-side of the crank case.
Oh :stupid: I was convinced it was supposed to screw into the block for some reason. Thanks. I might not be missing it after all then. :embarrass:
Yeah definitely not. I can see how it really would be a massive vacuum leak if I were missing the valve. But I see it haha. I'm so embarrassed.
Edited by ll77
  • 3 weeks later...
Hello once again,
I have been ill lately, turned out to be a case of acid reflux. It is also finally that time for me to fill college applications again, so it's going to be a busy month.
So last week, I prepared for the rain by putting my cowl back on, throwing the new wipers on, giving her the whole Rain-x treatment. I took off my PCV, it was very schticky. I sprayed it off w/ CRC electrical contact cleaner for fear of there being plastic in there. It worked beautifully. No noticeable difference though. Then it was time for dinner.
I've been turning the big issue over in my head lately, which is that she won't pass smog due to an incredible excess of CO emissions, HC and NOx are very well within limits.
With that being said, I don't understand how I could be running lean, but making such amounts of CO. CO is produced in combustion situations deprived of oxygen. If I am running lean, that means my air>fuel, which should provide plenty O2 for for combustion.
I have a theory that involves my VERY advanced valve timing:
When the piston is at the end of the exhaust stroke, the exhaust valve closes, the intake valve opens and allows spent exhaust into the manifold (?), and the oxygen-poor exhaust gases recirculate into the cylinders at the intake stroke, resulting in a low-oxygen situation in compression and power strokes, resulting in excess CO. This could also cause my low-vacuum situation.
A neighbor suggested I advance my ignition timing to compensate, but ignition timing is irrelevant to valve timing in this regard, because no matter how much I crank up my ignition advance, I will only be further from timing both according to "crank timing," because that is really the central timing event, valve and ignition timing should both be accommodating the piston cycles.
I remember waaay back, I used to think it was because of my exhaust leak, but now knowing that I have no O2 sensor, no.
But I really don't know. Gotta give me credit for trying. Still don't know why it's lean though. I'd appreciate some thoughts, thank you.:)
  • 4 weeks later...
I've got bad news again, I've been noticing some hiccups, like as if the engine shuts off for a split second then comes back to life, kind of like how my heart skips a beat when it happens. Then last week it's started doing the "runs like crap for a few minutes on 2nd start-up" thing, then returns back to normal. Both symptoms lead me to think that the AFM is taking a dump on me. Couldn't be happening at a worse time, midterms are this week!
My question is, what kind of problems could running a 78 AFM + ECU on a 76 cause, if any? The only explanation for why the 76 AFM I bought doesn't work with my car, is if the PO swapped the AFM and ECU for a 78 setup, which has the same ECU # of A11-600-000, but different AFM models. So now I'm thinking about getting a 76 ECU, considering they come pretty cheaply sometimes on hybridz. Good idea, you think?
I could be wrong, but momentary lapses in running are most likely due to a bad connection somewhere -- maybe your ignition. It's unfortunate that these intermittent problems are so hard to track down. I fear you're going to have to put up with the hiccups until the car dies and stays dead. Then you might have a chance of diagnosing it.
Until that happens, I'd carry an emergency diagnostic kit with you for testing on the side of the road (or hopefully in a parking lot) somewhere. Carry some starter fluid to spray into the intake. If the engine will fire and then die on a good shot of starter fluid in the intake, then the problem is fuel related. If you can't get it to fire and die, then it's probably ignition related. Alternatively your entire system might be dead. Check for power to the (+) terminal of the ignition coil with a multimeter. Also go through your fuse box to see which circuits have power and which don't. So I guess that's your emergency diagnostic kit -- a multimeter and a can of starter fluid. Good luck! ;)
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
