Posted August 17, 201113 yr comment_364221 Does anybody run this plug? Will my stock '77 like it? Link to comment https://www.classiczcars.com/forums/topic/40532-ngk-zfr6-11-v-groove-plug/ Share on other sites More sharing options...
August 17, 201113 yr comment_364223 Works fine Link to comment https://www.classiczcars.com/forums/topic/40532-ngk-zfr6-11-v-groove-plug/#findComment-364223 Share on other sites More sharing options...
August 17, 201113 yr Author comment_364235 Thank you and what a great looking car you have. Link to comment https://www.classiczcars.com/forums/topic/40532-ngk-zfr6-11-v-groove-plug/#findComment-364235 Share on other sites More sharing options...
August 17, 201113 yr comment_364238 I am running ZFR6F-11 in my 240. They are extended tip, and the Z loves them. Link to comment https://www.classiczcars.com/forums/topic/40532-ngk-zfr6-11-v-groove-plug/#findComment-364238 Share on other sites More sharing options...
August 17, 201113 yr comment_364260 If your car is running clean plugs but you worry about detonation due to higher ambiant temperature, turbo boost or higher compression, you can try a colder plug (ZFR7F). Just make sure it does not foul up due to black deposits. Link to comment https://www.classiczcars.com/forums/topic/40532-ngk-zfr6-11-v-groove-plug/#findComment-364260 Share on other sites More sharing options...
