hello, ive been wanting to pick up a 240z as a project for the longest time, and i found this car at a junk yard. it needs a lot of work but the body looks pretty good other than the driver side rear quarter panel. i dont have great pictures but can this be repaired and if so, how can it be done and how much would it cost.
The rear quarter can probably be pulled/pounded out without too much effort or expense. I think I'd be a little more concerned about the sprung rear hatch. Getting that to fit and close properly might be a bigger task if the hinges and hinge mount points are bent. The hatch, itself, may be a candidate for replacement rather than repair.
Let us know what you do.
Dennis
Thanks for the quick reply, that's good news. As far as the hatch goes, it will be replaced. I'm just not sure if I should go with a fiberglass piece or a factory piece
Yes that is repairable but check for rust. to pull out the dents I would weld a block on it and use a slide hammer, a little hammer and dolly work and heat shrinking. It should be fine. or you could cut out and weld in a strait piece but I think straiting the original would work out better.
will do, thanks
can you close the back hatch to see if the gaps around the hatch are ok?
this is a way you make sure the back half of the car is square.
im gonna go take another look at it tomorrow, ill check this out to
It looks a little ruff for a original restoration what it your intent if you got the car
well my plan is to drop my sc ls6 into it and use it for daily/track duty. the car is going for $500, i might be able to get it a little cheaper.
That would be a good one if it isn't rusted. In 72 they did some improvements to the rear that will help you in getting it setup over a 70-71 Z. From what I hear it is easier to swap a 240SX limited slip rear in also
