Posted August 20, 201113 yr comment_364427 Recently purchased my first Zcar, 1982 280zx 2+2 nonturbo While putting the engine back together ran into this part and not sure what it is. Can anyone identify it please? Also does anyone know what it connects to? Thank you very much for the help. Eric Link to comment https://www.classiczcars.com/forums/topic/40558-need-help-with-vacuum-lines-and-identifying-a-part/ Share on other sites More sharing options...
August 21, 201113 yr comment_364516 it has some function related to the cruise control module. I think Link to comment https://www.classiczcars.com/forums/topic/40558-need-help-with-vacuum-lines-and-identifying-a-part/#findComment-364516 Share on other sites More sharing options...
August 22, 201113 yr Author comment_364550 it has some function related to the cruise control module. I thinkI thought it may be the Fast Idle Control Device, but I still have no idea what it should connect to. Link to comment https://www.classiczcars.com/forums/topic/40558-need-help-with-vacuum-lines-and-identifying-a-part/#findComment-364550 Share on other sites More sharing options...
August 29, 201113 yr comment_365048 I thought it may be the Fast Idle Control Device, but I still have no idea what it should connect to. e_yates, I believe that this part is the FICD Actuator. It's displayed as Part Code 27655Z in this 280zx Throttle Chamber diaagram: http://bit.ly/o1Pp4T Let me know if this is right on the money! Link to comment https://www.classiczcars.com/forums/topic/40558-need-help-with-vacuum-lines-and-identifying-a-part/#findComment-365048 Share on other sites More sharing options...
October 7, 201113 yr comment_368504 Hope the photos help, as I'm at work and can't dash out and take specific photos, they'll have to do... I suggest you find a copy of the Factory Service Manual; by far surpasses the chilton/haynes books. Link to comment https://www.classiczcars.com/forums/topic/40558-need-help-with-vacuum-lines-and-identifying-a-part/#findComment-368504 Share on other sites More sharing options...
