My wipers and washer are not working. Motor is new and washer tested good. The fuse in the fuse box under the console is good.
Are there fuses for the wiper in any other location? How can I test thhe switch on the steering column to insuure its gooc.
https://www.classiczcars.com/forums/topic/40586-71-240z-wipers-not-working/
Find the wiring diagram. You'll find it in the BE section of the supplement manual posted at XenonS30. It should indicate any inline fuses. The switch can be tested for continuity at the different on positions.
Are you sure you got the wiper motor for the 71?
Yes the motor is for a 71, I got the supplment and will check the switch, Thanks
