Hey guy,
So i got a 73' 240Z and im looking to put some wheels and tires on after I get the struts and springs done.
Im planning on putting Tokico Illumina struts with Eibach progressive springs. Is this a good set up?
After thats done im wanting to put 16x8 Rota RB's in the rear and 16x7 in the front. Both have a 0 offset. Will this ccause any rubbing issues? What will fitment be like? Also what tire sizes would you recommend?
Thanks for the help.
Is it a good setup for what? Is the car going to be a street car, see track use, drive your wife to the grocery store, hit some Dukes of Hazzard jumps?
Wheel and tire sizing has been discussed at length, you should be able to find all the info in a search.
Street car will be the main purpose. Ill try and look more into the wheel and tire sizes. I couldnt seem to find anything with regards to the 0 offset which is what concered me the most.
I'm pretty sure zero offset RBs don't exist, I'd double-check that number. Here is the offset list off Rota's website: http://www.rotawheels.com/wheels.asp?wheelid=34
The Illuminas with Eibachs is a nice setup for a street Z, even works fine for the occasional autoX. Just avoid bad roads.
