Posted August 28, 201113 yr comment_364954 Am I seeing the parts CD correctly? The oil pan reinforcements go between the block and the pan gasket? Where should I put gasket seal, between the pan & gasket, between the gasket and the reinforcements and also between the reinforcements and the block?Thanks Link to comment https://www.classiczcars.com/forums/topic/40615-l28-oil-pan-reinforcement-parts/ Share on other sites More sharing options...
August 28, 201113 yr comment_364964 The reinforcements go on the outside between the bolts and the pan. Only the gasket and sealer goes between pan and the block. Link to comment https://www.classiczcars.com/forums/topic/40615-l28-oil-pan-reinforcement-parts/#findComment-364964 Share on other sites More sharing options...
August 28, 201113 yr comment_364966 that is correct! Link to comment https://www.classiczcars.com/forums/topic/40615-l28-oil-pan-reinforcement-parts/#findComment-364966 Share on other sites More sharing options...
August 28, 201113 yr Author comment_364973 Thanks to both of you! What I thought I was seeing did not make sense.Thanks again!Hap Link to comment https://www.classiczcars.com/forums/topic/40615-l28-oil-pan-reinforcement-parts/#findComment-364973 Share on other sites More sharing options...
