I was replacing some wonky fuel system parts while I was trying to find out why my NOS fuel pump is howling like it's got a belly-ache. I decided to replace the Fuel Damper. Having already flushed the tank, I installed a filter between the fuel tank and the pump (as I had read in the hundreds of earlier posts) as well as the Pressure Regulator -but alas the pump is groaning like its had too many Jalapenos!
Finding a Fuel Damper was not as easy as I thought, so I remembered that these were Bosch L-Jetronic systems and that there were many cars that used L-Jetronic. What I found was a Mercedes part (W0133-1615150) here: http://www.importeccatalog.com/item.wws?mfr=BOSCH&sku=W0133-1615150&source=GOOGLEBASE.
I thought that I would pass the number along. It is Bosch (OEM), it matches the picture in the FSM and it was $65! It may not solve the noise, but it was the cheapest first step.
https://www.classiczcars.com/forums/topic/40628-fuel-damper-part-source/
