tanny Posted December 31, 2002 Share #1 Posted December 31, 2002 Will a radiator shroud from a 280z fit a 240 z? I have a 73 240z manual with no AC. Thanks. Link to comment Share on other sites More sharing options...
2ManyZs Posted December 31, 2002 Share #2 Posted December 31, 2002 Sorry, the shroud for the 280 radiator is larger than the one for the 240. The 280 radiator is a couple inches taller and a bit wider than the 240 rad. The mounting holes on the 280 shroud will be nearly at the outside edge of the 240 radiator. You might be able to fab up some flat pieces of aluminum or steel scraps to mount it up, but then you will need to make sure you have it centered over the fan correctly. It won't be exactly "pretty" but it could be made to work if you can't find a 240 shroud, which are kinda hard to find. Link to comment Share on other sites More sharing options...
tanny Posted January 1, 2003 Author Share #3 Posted January 1, 2003 Thanks. I haven't looked around yet for the 240 shroud. May have to fabricate something as you suggested. Link to comment Share on other sites More sharing options...
