I know the information is here but I find conflicting information. Will 225/60/14’s rub? I have a late 73 240Z with a stock suspension (poly bushings and Bilstien shocks) and nice old slotted wheels. 0 offset 6 inch wide. The valance is gone and I have an airdam. Is this a good choice?
Edited by philbar73
You find conflicting information because even with the same specications, tire sizes differ between manufacturers. Before I switched to Panasports (225/50-16), I had the same slotted mags with the same tire size as you, 225/60-14. Tires are Yokohamas and there were no fit problems when I was running them. Look up your tires on tirerack and it will tell you the true dimensions.
The valance is where you will rub, if it is gone, you should have no problem. I'm running 235/60 14's all the way around, rubbed on all 4 corners due to weak springs, replaced the front springs which eliminated 90% of the contact. once I finish the rears, should no longer be a problem. So, if you have soft springs, you might rub a bit.
