Negative Camber
biker
Does anyone know where I can get hold of an adjustable negative camber system. One that will allow me to adjust from current o degree up to 5 degree negative camber.
I have heard of systems that are fixed but also systems that use a shim to adjust. Just don't know where to get my hands on a decent one (read cheap).
:ermm:
  • 3 months later...
Fortuna supply an eccentric front camber adjuster kit which requires some welding of the Xmember but I strongly suggest that you have it installed by someone who knows how to locate it properly. See Ken at Accurate Suspension, Brisbane, for this work, tell him that Richard from the Z Car Club recommended him.
