September 15, 201113 yr Author comment_366575 The FSM makes a note of removing/breaking the carb linkage before lowering the transmission. Easy to overlook! All the steps in the FSM are straightfoward and easy to follow.Jimthat is one I'd have overlooked. That and that I think I have a FSM on CD somewhere too, forgot all about that. All the regular jobs on the Z I've done so many times I forget about things like that for the less often stuff.thanks!Trevor Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-366575 Share on other sites More sharing options...
September 16, 201113 yr comment_366585 You can get a harbor freight transmission jack like the one in Zedyone's pic for pretty cheap. Especially if you get a 20% off coupon in the sunday paper. That puts it around $68. I have used the crap out of mine so far. This one drops pretty low so you don't have to have the car on extremely tall jack stands to get clearance. http://www.harborfreight.com/450-lb-capacity-transmission-jack-39178.html Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-366585 Share on other sites More sharing options...
September 16, 201113 yr comment_366616 Bench-pressing a tranny while under the car is the only weight-training I do......and working under an S30 dashboard is the only Yoga I do. Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-366616 Share on other sites More sharing options...
September 16, 201113 yr comment_366670 You can get a harbor freight transmission jack like the one in Zedyone's pic for pretty cheap. Especially if you get a 20% off coupon in the sunday paper. That puts it around $68. I have used the crap out of mine so far. This one drops pretty low so you don't have to have the car on extremely tall jack stands to get clearance. http://www.harborfreight.com/450-lb-capacity-transmission-jack-39178.htmlI picked up the same one for my Powerstroke - at 175 pounds I wasn't going attempt to bench press that transmission. It was a godsend, trans slid in and out like butter, my first thought, "why didn't I get this along time ago for the Z?!" Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-366670 Share on other sites More sharing options...
September 16, 201113 yr comment_366681 These trannies only weigh around 60-70 lbs. I would have a few extra pieces of 4x4 under the car while you are there, because you WILL need to adjust height while you are engaging the input shaft with the crank. If you have a radiator shroud you may want to take it off. As stated above, you need to support the rear of the motor with a jack and you will need to adjust the jack at times to change the inclination of the motor for alignment. When you do this, the fan can hit the shroud, and possibly the radiator. Keep an eye on the area up front as you adjust the jack.I paid around $150.00 for the clutch disk, pressure plate, throwout bearing and alignment tool. You can decide whether its worth it or not to replace these depending upon the condition of the existing one. Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-366681 Share on other sites More sharing options...
September 17, 201113 yr comment_366703 Two things I have done that helped without a trany jack are: you can support the rear of the trany with a strap and a pipe or wood block through the shifter hole and using a jack to lift the rear of the engine to help align it to the transmission when reinstalling it. Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-366703 Share on other sites More sharing options...
September 17, 201113 yr Author comment_366708 I paid around $150.00 for the clutch disk, pressure plate, throwout bearing and alignment tool. You can decide whether its worth it or not to replace these depending upon the condition of the existing one.I saw where the aftermarket ones weren't too bad, but I wasn't sure if that was an item that I'd just be asking for trouble if I didn't stick with Nissan parts. Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-366708 Share on other sites More sharing options...
September 17, 201113 yr comment_366713 At 70 lbs, yes an average guy can lift one relatively easy, but it's the jack's ability for finite adjustment and movement (more the floor jack model too) while suspended which makes it so valuable - all 4 casters pivot, height & angle adjust-ability, you won't be disappointed. At $70 it sure saves a lot of cussing. Edited September 17, 201113 yr by preith Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-366713 Share on other sites More sharing options...
October 3, 201113 yr Author comment_368007 It is done!!!Thanks to everyone for all the tips.Found a $50 off and free shipping at Advanced Auto Parts online site for a beck/arnley clutch set and replaced the rear main seal while I was in there, new front and rear seals on the transmission and the axle seals on the diff also replaced and the seal on the fuel sending unit.Everything actually went back together easier than it came apart, which is a first.Trevorhttp://240Z.me Edited October 3, 201113 yr by ta240 Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-368007 Share on other sites More sharing options...
October 3, 201113 yr comment_368015 Congrats on a great job! Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-368015 Share on other sites More sharing options...
March 14, 201213 yr comment_384001 I am going to do the same job and bought a scissors-style transmission jack from Harbor Freight. With the transmission strapped onto the jack it is 22 inches tall! I have some 24-inch tall Jackstands and some other smaller ones too. Any suggestion for the best location for the jack stands for this project, or do I need some timbers also? Thanks for your suggestions, Gary Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-384001 Share on other sites More sharing options...
March 14, 201213 yr comment_384007 I did it myself just yesterday. Took me about 4 hours. My arms and shoulders are sore today (I am no weight lifter). I was using a regular floor jack, pumping it up with my leg and guiding the trans with both arms. Laying on the cold floor was no fun. Link to comment https://www.classiczcars.com/forums/topic/40791-one-man-job-removing-and-replacing-transmission/?&page=2#findComment-384007 Share on other sites More sharing options...
