Email logins are now active ×
One man job? Removing and replacing transmission
ta240
I did the un-graceful option of pushing the transmission off the jack and dragging it out from under car to get it to fit. That went okay. Trying to get the transmission slid back on the jack while under the car wasn't as easy, but still not too hard. I got very lucky. Everything went back together faster than it came apart on mine.
Years and decades ago - - - I took two of the transmission bell housing-to-block bolts to the local ACE Hardware. I think they were 1.5 x 10mm bolts - and bought two matching thread size bolts - except with about 3 to 4 inches longer shoulders.
Took them home and cut the hex head off - when reinstalling the tranny - i screw them by hand into the top two holes in the block - then line the top two holes in the bell housing up with them - the tranny slides right into place... Saves a lot of twisting/moving/shaking effort with the tranny..
FWIW,
Carl B.
The right size plastic cap off a can of spray paint - will slip right in the tail and prevent about 98% of the mess... add a little duct tape and your good to go... Of course if you do this job often -you have kept the end off an old driveshaft to stick back in there.. LOL
FWIW,
Carl B.
Phenominal ideas. I wish you had posted those 4 days earlier. ;-) McMaster threaded rod or studs would have been perfect to slip the trans into place. I found a plastic cap that is the perfect size to slide INTO the rear seal. It makes a perfect seal.
Sometimes it helps to leave the trans in 4th or 5th gear so you can twist the output shaft a little, to get the clutch splines to mate.
Edited by cygnusx1
FWIW,
Carl B.
I did exactly the same thing for my Toy 4x4 trans. I tapered the cut off ends though and then cut slots in them so I could back them out with a screwdriver after the trans was in place.
I too pulled the yoke off a spare driveshaft and I always use that when I drop a trans. Some bailing wire hold the yoke tight to the trans so it doesn't fall off and leak fluid.
  • Who's Online   1 Member, 0 Anonymous, 222 Guests (See full list)
