April 27, 20204 yr comment_598145 I know this is an old topic but does anyone know if the bellows screws out or is it a slip fit just held in by the set screw? My set screw broke so I had to drill it out but the bellows is still stuck. I don't want to ruin the bellows. Edited April 27, 20204 yr by SurferD Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598145 Share on other sites More sharing options...
April 28, 20204 yr comment_598241 It is a slip fit. Try to hammer it lightly from outside. Maybe heating and then cooling will release it. Bellow.mp4 Edited April 28, 20204 yr by BlueZee language Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598241 Share on other sites More sharing options...
April 28, 20204 yr comment_598245 That was a great explanation thanks! The crimp on the aluminum ring failed but I was able to tap the brass out. I'll drill/tap the ring to M6x1.0 and use a new set screw and restake it in the steel barrel. The bellows shaft was really corroded so after cleaning/lube it will work fine. I also got the main part taken apart like the pics above and it's now free to rotate if adjustment is needed. Looks like both diaphragms are in decent shape after 50 years. Edited April 28, 20204 yr by SurferD Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598245 Share on other sites More sharing options...
April 28, 20204 yr comment_598255 Here is also a picture in slightly better resolution: Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598255 Share on other sites More sharing options...
April 29, 20204 yr comment_598288 I don't have that upper part. My FSM has the same picture but it's not as crisp. The barrel actually deformed when the brass shaft was hammered out. So I took a washer the exact ID size and a long socket and put it in the vise and viola' back to stock shape. I did get a backup on eBay in case this one fails. I did learn however from carpartsmanual there were different units for automatic/standard transmissions and years. Mine is stamped 66P15. Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598288 Share on other sites More sharing options...
April 29, 20204 yr comment_598291 45 minutes ago, SurferD said: I don't have that upper part. They started with that upper part in 73. Prior years didn't have that. It's a solenoid valve that they use to disable the opener system when the car isn't moving. In other words... When you blip the throttle at idle sitting still, it won't let the opener pull on the linkage. Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598291 Share on other sites More sharing options...
April 29, 20204 yr comment_598297 You always know Cap! Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598297 Share on other sites More sharing options...
April 29, 20204 yr comment_598298 Naaaa... Most times I just make stuff up and usually people don't bother to check it. !! Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598298 Share on other sites More sharing options...
April 29, 20204 yr comment_598303 Haha yea if you say something with enough confidence no one doubts you. I’m always learning something about these cars. Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598303 Share on other sites More sharing options...
April 29, 20204 yr comment_598307 On 11/24/2012 at 3:48 AM, Captain Obvious said: ..They could have put a bleed vent into the control valve #2.. @Captain Obvious : Isn't it a bleeding hole that you were thinking about, in 2012? Edited April 29, 20204 yr by BlueZee Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598307 Share on other sites More sharing options...
April 29, 20204 yr comment_598315 @BlueZee, Thanks for that pic! Kinda hard to tell for sure, but yes, that may be a bleed hole. if it is, it would be an answer to something that has bothered me for years. Does that hole actually go anywhere, or is it just a dent from the locking setscrew? Can you pass air through that hole? Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598315 Share on other sites More sharing options...
April 29, 20204 yr comment_598326 Picture explains a lot. Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=2#findComment-598326 Share on other sites More sharing options...
