July 13, 20204 yr comment_602562 I don't have one here handy to compare, but I believe the servo diaphragms should be airtight and hold a vacuum. I think if yours won't hold, it's probably got a hole (probably age crack) in the diaphragm. Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=4#findComment-602562 Share on other sites More sharing options...
July 13, 20204 yr comment_602568 Might be off topic but, can issues/leaks with this system cause a higher idle at idle? When pull to a stop after driving around the idle is noticeably higher (1-200rpm), if i give the throttle a blip, the idle returns to normal. I've changed out the return springs thinking that was related but no change. Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=4#findComment-602568 Share on other sites More sharing options...
July 14, 20204 yr comment_602584 Doubtful unless the linkage to the throttle opener system is binding up or something. Next time your idle hangs up, pop the hood and start pushing on different places on the linkage(s) and see if you can figure out where it's hanging. Link to comment https://www.classiczcars.com/forums/topic/4081-throttle-opener-control-system/?&page=4#findComment-602584 Share on other sites More sharing options...
