Healey Z Posted September 20, 2011 Share #1 Posted September 20, 2011 (edited) I just realized that I already posted this and got some good responses....I'm getting old. Edited September 20, 2011 by Healey Z blame it on age Link to comment Share on other sites More sharing options...
240260280z Posted September 21, 2011 Share #2 Posted September 21, 2011 Link to comment Share on other sites More sharing options...
Reverend Posted September 21, 2011 Share #3 Posted September 21, 2011 I'd love to get one of those. Trying to change my Z to euro model for obvious reasons. Link to comment Share on other sites More sharing options...
Healey Z Posted September 21, 2011 Author Share #4 Posted September 21, 2011 (edited) I would love one like that. The only one I could find on the planet is from Z Therapy... $150 + $60 core + $20 shipping. Edited September 21, 2011 by Healey Z added pic Link to comment Share on other sites More sharing options...
240260280z Posted September 21, 2011 Share #5 Posted September 21, 2011 I have one but I'm hanging on to it. Link to comment Share on other sites More sharing options...
Bonzi Lon Posted September 22, 2011 Share #6 Posted September 22, 2011 I really like the way mine turned out, can't have enough polished bits. The intakes will be next. Bonzi Lon Link to comment Share on other sites More sharing options...
Zedyone_kenobi Posted September 22, 2011 Share #7 Posted September 22, 2011 You sir have a lot of time on your hands! HAHA,but your work is beautiful. Link to comment Share on other sites More sharing options...
tlorber Posted September 22, 2011 Share #8 Posted September 22, 2011 I took the one from my '73 and cut the extra "lobe" off the bottom, along with some of the brackets on the top, (I used a combination of a band saw and angle grinder). There was a small hole that I had to have welded up where the egr valve was. It was a lot of grinding, sanding and polishing but it came out nice. Link to comment Share on other sites More sharing options...
Healey Z Posted September 23, 2011 Author Share #9 Posted September 23, 2011 tlorber, That is my plan. Did you cut and smooth before you had the opening welded shut? Link to comment Share on other sites More sharing options...
tlorber Posted September 23, 2011 Share #10 Posted September 23, 2011 I would say I did most of the cutting and grinding before the weld so that I knew what the contour should be. Obviously the welded area will need to be sanded and polished as well. Link to comment Share on other sites More sharing options...
ollie Posted September 23, 2011 Share #11 Posted September 23, 2011 Try Norm at Zeddsaver...he provided me with EVERYTHING to remove the Webers on my '73 inlcuding a new, never used set of '72 SU's, linkages, heat shield and euro balance tube. I don't recall how much the balance tube alone was, but I'm very much looking forward to the clean appearance this will bring, along with the new Stahl header. Link to comment Share on other sites More sharing options...
TomoHawk Posted September 23, 2011 Share #12 Posted September 23, 2011 After the welding, were you able to polish the welds? Did it all come out equally shiny, like it was solid aluminum, or can you tell where the welded spot was? Link to comment Share on other sites More sharing options...
