The car looks amazing!!!
I was chatting no later than yesterday about classic car in Poland with colleagues - I was in Tychy & Krakow this week ;) So it's good to see some Classic Z around!
Simply PERFECT!
I think the tail muffler can be turned around end to end, 180 degrees, and tucked fully up into the space behind the wheel.
Edited by cygnusx1
Thanks guys! The seats seat pretty good in the car but I had to make custom mount brackets to make them fit. Also, because of the rollbar the passenger seat is a little more forward that the driver's but there is still enough space.
The exhaust... I don't know why but I somehow I started to like it the way it is. I bought it like that and only cut the tip because it was bent downwards. It also has a chrome tip added now.
  • 6 months later...
In case "qusbo" returns... it might not be the roll bar stopping the passenger seat from going back. The original passenger seat tracks on do not allow the seat to go as far back - as the drivers side does. I've ran into this on several 240Z's - I usually just install a set of driver side seat slides on the passenger side.
FWIW,
Carl B.
