i have changed the plugs wires and rotor and cap the plugs are fouling after a few cranks and it misfires in cyl. # 6 the fuel pump also does not come on with the ignition switch i hav do direct wire it and also was concerned if tht may be causing mor problems ?? i am new to the z world and appriciate any help THX!!:)
Use the search function. Read a lot more. Be as descriptive as possible in your posts. Put some effort in to good grammar and spelling (i hav do direct wire it), you'll get more help. Download the FSM and read the Engine Fuel section - http://www.xenons130.com/reference.html Do the tests that fit your problem.
Good luck.
