Blue - I presume you have your interior dog-leg trim piece for the area below the quarter window. Hold that piece against its body location and you will see a notch for the wiring harness. That is the location for the for the harness to enter the body cavity on its way to the back.
As to the door sill question - the harness runs along the inside of the car from the firewall back the point I mentioned. You should see some of the flat hold-downs along this path as it jumps over the two seat braces. When you finish, the harness will be covered by the pebble-grained vinyl trim that runs along the interior rocker panel.
Jim
