Hi,
Can some one please run through the path for the rear wiring harness from the passenger foot well to the back.
Where does it enter the passenger door sill ?
'i assume the big grommet goes where it enters the sill?
Thanks
Blue - I presume you have your interior dog-leg trim piece for the area below the quarter window. Hold that piece against its body location and you will see a notch for the wiring harness. That is the location for the for the harness to enter the body cavity on its way to the back.
As to the door sill question - the harness runs along the inside of the car from the firewall back the point I mentioned. You should see some of the flat hold-downs along this path as it jumps over the two seat braces. When you finish, the harness will be covered by the pebble-grained vinyl trim that runs along the interior rocker panel.
Jim
Thanks a million Jim ! I was just checking to see if any one answered and I saw no one had.... then as I back stepped I saw 1 reply.
I'll route the harness then call it a night. 9:25pm here
