Wires at Rear Right Side marker?
240260280z
Blue - your pic is of the left (driver's) side. You have three connections in this area: side marker light, power antenna, & radio speaker. I can't recall which pair does which and my car is all closed up now. The power antenna is probably at the end of the line, these are probably side marker and speaker. This should help you with a schematic search. Don't forget to check the supplemental FSM.
Jim
  • 1 year later...
