Posted September 28, 201113 yr comment_367640 Ok so I've been trying to take off my front fender and I think I've almost got it however one thing I do not have done yet is the head light wire and side flasher light wire. For the head light it looks like I can just take the lamp holder out and the wire will come with it. The side flasher is more complicated though because it does not fit through the opening that it mounts in. This would be easy if these wires disconnected at some point but it's all one fluid wire.Does anyone know how to get the side flasher out of the fender?edit: this probably should've gone in body/paint sorry. Link to comment https://www.classiczcars.com/forums/topic/40921-head-and-side-light-wiring-removal/ Share on other sites More sharing options...
October 2, 201113 yr comment_367974 On my 75 the side marker lights are held on with 2 screws mounted on the outside and the wires have push on connectors about 4" long which connect into the wiring harness. Link to comment https://www.classiczcars.com/forums/topic/40921-head-and-side-light-wiring-removal/#findComment-367974 Share on other sites More sharing options...
October 2, 201113 yr Author comment_367977 Yes mine has two screws as well I have it taken off it just didn't look like it was a plug but I guess I can pull. It'll either rip or work hahaThanks! Link to comment https://www.classiczcars.com/forums/topic/40921-head-and-side-light-wiring-removal/#findComment-367977 Share on other sites More sharing options...
October 2, 201113 yr comment_367980 Those plug in connectors have a tendency to be real tough to get apart, on mine several broke off the wire, they are after all over 30 years old, a little "twist and shout" works. Link to comment https://www.classiczcars.com/forums/topic/40921-head-and-side-light-wiring-removal/#findComment-367980 Share on other sites More sharing options...
