Posted October 1, 201113 yr comment_367900 76 280 will just shut down. Happens randomly at any speed. When restarting it will start/stop 5 to 10 times then runs fine for anywhere from an hour to a week. Link to comment https://www.classiczcars.com/forums/topic/40942-ignition-issue/ Share on other sites More sharing options...
October 1, 201113 yr comment_367903 Tach needle drop first like rock or follow engine speed as car dies? Ignition versus fuel. Link to comment https://www.classiczcars.com/forums/topic/40942-ignition-issue/#findComment-367903 Share on other sites More sharing options...
October 1, 201113 yr comment_367911 Check the wiring near the ballast resistor / coil Also check the wire going from the coil to the dizzy, thats what happened to me once the wire was stuck up inside the rubber Link to comment https://www.classiczcars.com/forums/topic/40942-ignition-issue/#findComment-367911 Share on other sites More sharing options...
October 2, 201113 yr comment_367948 Check the 2 fuseable links on the battery, I just found that mine were killing power to the ECU. Link to comment https://www.classiczcars.com/forums/topic/40942-ignition-issue/#findComment-367948 Share on other sites More sharing options...
