Posted October 3, 201113 yr comment_368041 Looking to buy the following wee parts to finish off a Jan 71 240z resto:center valence panel "chin" Why? Because the paint shop smashed it when towing the car on its dolly then they tried to fix with bondo.passenger door window scissor assembly Why? Because the lower wheel is missing.wedgie striker-guide-things on doors below the latch Why? Because they crumbled.metal panel clips for door and trim. Why? Because some were missing240z drivers door mirror Why?Because it disappeared during the restoengine vent ducts Why,because they are rotten.yellow plastic marker light.Why, because I over tightened and cracked itkeys cut ? (Where can I get blanks?)red touch up 905 paint ? (Where can I get this?)emissions vacuum switch (engine compartment on frame below coil) Why, because it is missingDriver door spring (in hinge) Why, because it is missing1/2shaft hardware (nuts washers and bolts to hub flange and nuts and washed to differential flange ) Why, because I had to cut the rotten rusty originals off.Plastic Rivets Link to comment https://www.classiczcars.com/forums/topic/40955-final-stuff-i-need-to-finish-the-z/ Share on other sites More sharing options...
October 3, 201113 yr comment_368043 Looking to buy the following wee parts to finish off a Jan 71 240z resto:passenger door window scissor assembly Why? Because the lower wheel is missing.Looks like the window regulators are the same for all 240Z. I think I have one.metal panel clips for door and trim. Why? Because some were missingMight have a few of these kicking around too. How many are you missing?yellow plastic marker light.Why, because I over tightened and cracked itI know I have one of these, but not sure how good it is.keys cut ? (Where can I get blanks?)Jan. '71 is the split - is the ignition key single-cut, or double-cut?red touch up 905 paint ? (Where can I get this?)I got my 905 touch up from the shop that painted the car. That way I could be more certain it would match the paint on the car. I don't think I'd trust any off the shelf to match the custom mixed that was sprayed on the car. (Of course, three years later, mine has all dried up.)Plastic RivetsStill available new from Nissan, or numerous online vendors. Link to comment https://www.classiczcars.com/forums/topic/40955-final-stuff-i-need-to-finish-the-z/#findComment-368043 Share on other sites More sharing options...
October 3, 201113 yr Author comment_368057 Thanks Arne,I just sent a PM. Link to comment https://www.classiczcars.com/forums/topic/40955-final-stuff-i-need-to-finish-the-z/#findComment-368057 Share on other sites More sharing options...
October 4, 201113 yr comment_368093 Blue: Let me know what you still need after Arne helps you. I am sure I most of what you want.Dan Link to comment https://www.classiczcars.com/forums/topic/40955-final-stuff-i-need-to-finish-the-z/#findComment-368093 Share on other sites More sharing options...
October 4, 201113 yr Author comment_368102 Excellent. PM me with your phone number and I'll ring you! Link to comment https://www.classiczcars.com/forums/topic/40955-final-stuff-i-need-to-finish-the-z/#findComment-368102 Share on other sites More sharing options...
October 4, 201113 yr comment_368103 Dan, I hope you can do better than I can.I knew I had two window regulators, thought they were a pair from the same parts car. Wrong! I've got two LH, no RH. So I struck out there.I've got three spare amber sidemarker lenses, all three have at least one crack. Don't know why I've kept them this long.I did come up with seven of the trim panel clips. Blue, if you can't get those from someone in the same shipment as the rest, PM me an address and I'll drop them in the mail. Link to comment https://www.classiczcars.com/forums/topic/40955-final-stuff-i-need-to-finish-the-z/#findComment-368103 Share on other sites More sharing options...
October 4, 201113 yr Author comment_368106 Perfect! Thanks! I'll talk to Dan then get back to you. Thanks again for checking you hoard! Link to comment https://www.classiczcars.com/forums/topic/40955-final-stuff-i-need-to-finish-the-z/#findComment-368106 Share on other sites More sharing options...
