Posted October 4, 201113 yr comment_368182 hello everyone, i searched around and haven't seen anything related to my issue, i was wondering if anyone has ever just removed the stock airbox and air filter and just placed two cone style filters filters in its place...basically as seen like this kit:http://www.thezstore.com/page/TZS/PROD/PFFC20/11-4010KIwill it do the same thing? if were to just mount two cone style filters? or is there more to this kit than just the air filtersthank you Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/ Share on other sites More sharing options...
October 4, 201113 yr comment_368190 SUs need air horns, which are included in the kit. Without the horns you will lose performance, not gain.But to be honest, I don't know that the gain (if any) from this kit will be significant. The stock airbox is not the limiting factor on Z horsepower. Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368190 Share on other sites More sharing options...
October 4, 201113 yr comment_368204 My question back to you isWhy do you want to draw in air from the hottest part of the engine bay?By the way, the redneck way is to cut the air horns out of the air cleaner and use those underneath the filter. Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368204 Share on other sites More sharing options...
October 5, 201113 yr comment_368242 I agree with the above. Other than the K&N filters, there is nothing there to improve performance. For around $45.00 you can get a K&N for the stock box AND keep the blowby tube in the air filter. Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368242 Share on other sites More sharing options...
October 5, 201113 yr Author comment_368271 ok thank you guys for all your input...i was about to order that kit, thinking it would add a lot more h.p...(well not a lot more, but more) i thought it was the more affordable-happy-medium kit, that would bring you close to a complete webber carb set-upthank you guys Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368271 Share on other sites More sharing options...
October 10, 201113 yr comment_368805 SteveJ said: My question back to you isWhy do you want to draw in air from the hottest part of the engine bay?By the way, the redneck way is to cut the air horns out of the air cleaner and use those underneath the filter.Ha, Im about to do that. I just want the noise from it. Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368805 Share on other sites More sharing options...
October 10, 201113 yr comment_368824 One common upgrade is to use the stock filter housing and plumb onto the snorkle and run to a cone filter in front of the core support. Does a couple of positive things for you. 1. allows the pickup of cooler air from out ahead of the engine. 2. you are still feeding both carbs from a common source. 3. You keep the air horns that are built in to the stock housing. There was a kit coming together awhile back that was very sanitary. Have we any updated information on that system? Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368824 Share on other sites More sharing options...
October 10, 201113 yr comment_368838 Bruce, this may be what you are talking about:http://shop.uniquezproducts.com/Cold-Air-Intake-Kit-Datsun-240z-260z-70-75-1300.htmAm thinking of getting one myself! Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368838 Share on other sites More sharing options...
October 10, 201113 yr comment_368839 duffman said: Bruce, this may be what you are talking about:http://shop.uniquezproducts.com/Cold-Air-Intake-Kit-Datsun-240z-260z-70-75-1300.htmAm thinking of getting one myself!Looks nice, if you don't mind losing the cold air feed to the driver's footwell vent. Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368839 Share on other sites More sharing options...
October 10, 201113 yr comment_368847 duffman said: Bruce, this may be what you are talking about:http://shop.uniquezproducts.com/Cold-Air-Intake-Kit-Datsun-240z-260z-70-75-1300.htmAm thinking of getting one myself!Yep, that be the one. Saw it at Canby. Nice lashup and can't quibble about the price. When we put a bullet in our aircleaner efforts we were charging $300 and were losing our hat, arse and overcoat on everyone we sold. Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368847 Share on other sites More sharing options...
October 10, 201113 yr comment_368849 Good point, Arne, shouldn't be too tough to plumb the pipe through a lower opening. Might need to modify opening as well. Link to comment https://www.classiczcars.com/forums/topic/40970-cone-filter-on-su-carbs/#findComment-368849 Share on other sites More sharing options...
