I went down and looked at Ben's(otomoto) 240k today and im missing the strips on the outsides of the doors. I guess that is the stripe your talking about.
Also so two chrome/steel bits on the rear fenders for my car are totaly twistered so somthing with a few dents would be better.
pedal box shifter also keen. Joys of buy a car in pieces neither of us really sure what was there.
Cheers Brad
  240K&Beyond said:
Wooden gear knob for me too (5spd) if you can fine one please.
But I'll be betting they have already gone or are rotten.
They are available on ebay ,
http://cgi.ebay.com/ebaymotors/DATSUN-5-SPEED-WOOD-SHIFT-KNOB-1200-240Z-510-240K-120Y-/370548062214?pt=Vintage_Car_Truck_Parts_Accessories&hash=item564662b806
I saw the price, and said to myself "what a joke"
Nigel
  240kconvertible said:
I might go back to cut out the bits at the bottom of the B pillar on the gold one as I don't have the split in the line on the vert and I want it.
If you see anything you want let me know and I will weigh up if I can be bothered going out and getting it for you.
I'm probably after the same section? I need the dogleg section for the drivers side (eg cut horizontal from the top of the wheel arch forward to the door, with a couple of inches of the inner wheel well left on) . The section of the blue on doesn't look too bad. If you can be bothered cutting it up?
I should be going back out in a couple of weeks, I'm cutting off the two doglegs on the one of the coupes for the vert but I will be happy to cut one off the others for you, there were pretty rusted though.
Kent , do you still need the rail? I have one for you
I also have a pretty good drivers door too
