Posted February 27, 200124 yr comment_105 I am considering buying a 71 240Z and i need some advice. It is my friends and has sat for 7 years. First it has a lot of body mods like fiberglass hood, front air dam, and fender flares. When it was on the road it ran really hot and i think it would overheat. It is not the oringinal motor. It has a 280 z motor with a 4 barel on it. Its a 4 speed and the body looks fairly nice. Last how hard is it to get parts for these cars and are they expensive? Any ideas would help greatly. Also what should I look for and how much should I pay?[This message has been edited by Brian (edited 02-26-2001).] Link to comment https://www.classiczcars.com/forums/topic/41-considering-a-z-and-have-questions/ Share on other sites More sharing options...
March 2, 200124 yr Author comment_106 Anyone? Link to comment https://www.classiczcars.com/forums/topic/41-considering-a-z-and-have-questions/#findComment-106 Share on other sites More sharing options...
March 2, 200124 yr comment_107 I would pay about $1200 considering it gets hot and the body is fairly nice. There are a lot of companies that specialize in parts for these cars. The 240Z is becoming a coveted car now because of its light weight and all around performance. They can consume time and money, but pays off in the end. It is like having second girl friend. If you are going to restore it you are going to pay some cash and if you drive it everday for fun very inexpensive no different in maintenance then any other sports car. I would get it if I were you. ------------------Here he comes, here comes speed racer he's a demon on wheels!!!!! Link to comment https://www.classiczcars.com/forums/topic/41-considering-a-z-and-have-questions/#findComment-107 Share on other sites More sharing options...
March 4, 200124 yr comment_108 I had the same problem with my 72' 240Z and one way I solved it was a new water pump and fan clutch. You may also have a intake manifold thermostat, if you do u should check that also. There are other reasons that it over heat, but other than that it sounds really good, just look for any rush spot because that where it will cost a lot to fix. It's well worth the time and effort if you plan to restore it, like I plan to do. Good Luck Link to comment https://www.classiczcars.com/forums/topic/41-considering-a-z-and-have-questions/#findComment-108 Share on other sites More sharing options...
March 4, 200124 yr Author comment_109 Thanks for the info. I am still considering it. It is still stuck in to snow and with another big storm coming it might be a while till i get to jack it up and get a look at the underneath. Link to comment https://www.classiczcars.com/forums/topic/41-considering-a-z-and-have-questions/#findComment-109 Share on other sites More sharing options...
