You're right on the approx. cost. I guess the pound isn't as strong as it used to be. Would the T-56 actually fit an S30 without (major) sheetmetal mods? It's been pointed out that a mostly stock L28 probably wouldn't have the torque for 6th gear, but perhaps with a turbo'd stroker it might be go. I've been trying to decide on whether to sell my spare L28 or to look for a diesel crank and build a much stronger engine than my warmed over original engine.
If I'm not careful I'll just end up looking for another chassis, build the stroker, buy the 6 speed, do two restorations concurrently, then have to sell both cars to pay for the divorce.
It fits the S30 with some persuasion from a BFH. The big problem is that it really doesn't give you ANY performance benefit, because the 6th is not moving 1-5 closer together. It's slightly closer ratio that a 280ZX 5 speed, but not a huge difference. I would expect that the extra 75 lbs (yep, it weighs 150 lbs) plus having to screw with a starter and crossmember and driveshaft to fit it would not be worth the hassle. It's your money, but I wouldn't do it. The reason the 510 guy did is because he was spraying nitrous on his turbo'd drag racer and blowing up the T5 trans.
Here is the one I was thinking of:
One for sale here: (Eastern Canada) Click
[TABLE]
<tbody>[TR]
[TD]Transmission[/TD]
[TD]1st[/TD]
[TD]2nd[/TD]
[TD]3rd[/TD]
[TD]4th[/TD]
[TD]5th[/TD]
[TD]6th[/TD]
[TD]Final[/TD]
[/TR]
[TR]
[TD]NISMO Reinforced Cross[/TD]
[TD]2.9071[/TD]
[TD]1.9888[/TD]
[TD]1.5373[/TD]
[TD]1.2179[/TD]
[TD]1.0000[/TD]
[TD]0.8624[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]Genuine 6-speed (FS6R92A)[/TD]
[TD]3.6264[/TD]
[TD]2.2000[/TD]
[TD]1.5412[/TD]
[TD]1.2132[/TD]
[TD]1.0000[/TD]
[TD]0.7674[/TD]
[TD]3.6920[/TD]
[/TR]
[TR]
[TD]Genuine 5-speed (FS5W71C )[/TD]
[TD]3.3214[/TD]
[TD]1.9023[/TD]
[TD]1.3084[/TD]
[TD]1.0000[/TD]
[TD]0.8378[/TD]
[TD]-[/TD]
[TD]4.0830[/TD]
[/TR]
</tbody>[/TABLE]
Edited by Blue
$7,500 for my sequential 5 speed and that included straight cut gears, the dog ring option, custom ratios, the gear indicator display I ran where the speedo was, an "A" box bellhousing, and the custom machined adapter plate.
